Removes an NTP server or peer from external clock source lists.
| ip-address | Specifies the IP address of the NTP server or peer. |
| ipv6_address | Specifies the IPv6 address of the NTP server or peer. |
| host_name | Specifies the host name of the NTP server or peer. |
N/A.
N/A.
The following command removes an NTP peer Missouri from external clock source lists
configure npt peer delete Missouri
The following command deletes an NTP server named 1000::1:
configure ntp server delete 1000::1 vr VR-Default
This command was first available in ExtremeXOS 12.7.
The ipv6_address option was added in ExtremeXOS 32.6.
